car is dying when warm
dsmrebel084
114
Mar 4, 2011
st.louis, Missouri
So this problem is getting worst. My car will die on hot starts and will sometimes die when coming to a stop. I searched and the only thing that I found that might cause this is a bad ect sensor. I ordered one already and it should be on the way. Can I get anymore ideas of what to check out? All help will be appreciated
Probably the temp sensor in the water housing. I had this same problem on my isuzu with the same symptoms. If your temp sensor doesnt tell the computer it's warmed up it's more than likely keeping the enrichment from start-up going.
