Car died w/ rattling noise
talongod
274
Nov 24, 2002
Mayfield Hts., Ohio
Ok today i went out to dragway 42 ran my car a few times then when i left on the way home about 10-15min. down the road my car stopped spooling it was like a non-turbo car..... i started to hear a weird rattling noise so i pulled over and my car started bogging out....... i revved it up a lil from the throttle under the hood and the noise got louder so i stopped and then it started bogging out and wanted to stall so i shut it off...... sounded like noise was by the timing belt so i took off the cover but it seemed to look ok as in not broken so i got it flat bedded home an hour away which cost me about 130 dollars what can this be any input please
THANX in Advance!!
This sounds like what happened to me, except less extreme. Sounds like an intercooler pipe has worked its way off. Check all your piping and do a leak test anyway just to make sure. The rattling noise you hear could be the loose pipe.
When it happened to me, I was driving and I heard a pop. The car started bogging like crazy, and as I was slowing down to the side of the road, the car just stalls.
wow i hope its that id be so happy but it started ticking also and the rattling was like knocking real loud sounds strange but wish me luck
No Buschur Racing said i can just get the balance shaft eliminator kit and a new oil pump
  • Wanted 6 bolt NT water pipe
    • chrisman287
