Cant remove B&M Short Throw!!! HELP!!
Go to the hardware store and get some super PB catalyst. It should be in a white can. Use sparingly it is like wd40 except it actually loosens stuck bolts. Why r u removing it and how much would you like for it?
Thanks guys. There are no bolts attached to anything. I got all the bolts off. The bule pivot sholder should just slide off, but like i saind, its stick. I will try to buy that stuff though and see what I can do.
Im keeping the short throw btw.
Thanks again.
  • Wanted 6 bolt NT water pipe
    • chrisman287
