Can't get into any gears
mattp_65
Supporting Member
528
187
Aug 16, 2004
Granite Falls, Washington
Can some one please look at my pics off my clutch to see if there is anything wrong? Also if it is still useable?
Mileage on clutch (ACT 2600) had about maybe 15,000-20,000 miles with about two dozen track launches in about 6 years. Flywheel has been resurfaced to proper step and has about 2,000 miles.
Trying to determine why it is hard for me to shift in any gear. Yes I did adjust the clutch pedal to proper spec per jacks video. Also replaced both clutch and master cylinder before dropping the trans.
The best way I could shift somewhat was adjust clutch pedal far out of spec with about a couple threads left on the rod and even with that I had clutch dragging at about 3-4k rpm.
Any help is appreciated. Thinking about getting a South bend clutch.
Thanks
Pics:
http://www.dsmtuners.com/forums/dri...-gears-pulled-transmission.html#post153418787
The clutch disc looks a little worn, but definitely usable. The more worn the disc is, the easier to disengage it will be so that isn't your problem. What brand is the clutch master that you bought?
That could be your problem. Some aftermarket masters have a piston that is too short which doesn't transfer enough fluid to the slave. If you still have to old one i would either rebuild it with an oem rebuild kit, or buy an oem or better quality one from rockauto.com
That clutch is worn but not quite done. You are not fully dis-engaging your clutch. How is the tob fork? Is it bent? try bleeding the system and adjusting the pedal to see if you can get it to dis-engage.
Get a Nabco clutch master cylinder. I would still definitely swap out the clutch and pressure plate as well too. Also, have you checked for play on the input shaft of the tranny? Do you see the slave cylinder move when you bled it?
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
