can't boost over 5psi
93AWDTalon1
175
Oct 15, 2004
Louisville, Kentucky
The car does great until it hits 4-5psi and then acts like it's cutting out or hitting some kind of limiter. but I don't have a fuel cut and I'm no where near the rev limit. the o2 sensor reads .92-.94 under boost. it has week old ngk's in it. everything looks good on the pocket logger but it acts like it's hitting some kind of limiter over 4-5psi. anyone got any ideas?
i dont see it say no boost leak. fuel cut is not the same thing. not even close. and the only way you know its not boost leak is to do a boost leak test
Hmm tough one. You've done the boost leak testing which was my first guess.
Could be your turbo taking a poop on you i suppose, the wastegate might not be working properly. After reading around some I found out that alot of people have a bad wastegate, it's being blown open to soon.
OR
Defective turbo or failure caused by oil feed/return/pressure issues.
I'm assuming you're referring to the car you have in your profile so I would check on the wastegate (is it internal or external).
Also check to make sure all your plug wires are connected down properly.
