Can you lower boost on 14b???
fast93accord
Feb 25, 2004
cherry hill, New Jersey
Hi, i'm going to be running a 14b on my car in a few weeks. I have one question someone here should be able to answer. Now on a stock dsm the 14b is set to run 12psi if i'm correct. I want to only run 6psi fo the first few days and was wondering if there is any way to lower the boost. Will a manual boost controller allow you to lower the boost? Is there a spring i can change to lower boost? Thanks in advance.
You can't go below the stock wastegate setting without modifying the wastegate actuator.
I don't think the springs are interchangeable on the 14b. One way to lower boost (and have horrible spool) would be to make the wastegate arm adjustable and keep the wastegate partially open at all times.
