Can You Identify This- Part 2
highboostintsi
55
Jan 25, 2006
prospect heights il, Illinois
sensor off the trans
have no idea where these 2 plugs go
and this comes off the thermostat housing...what plugs into here?
1st pic, backup sensor
2nd and 3rd must be a 1g thing
4th pic is for vacuum lines. (upper sensor) I believe emissions control.
Lower sensor I thought was ECT but Im probably wrong.
And just so you know "U" is not "you".
1st pic is reverse/back up sensor
2nd and 3rd is your coolant temp sensor and o2 plug. (the smaller one looks like the original coolant temp sensor broke off in it. Pull it out and plug it into the two prong sensor on the bottem. )
4th - plastic sensor is for emission(unnessacary) and the bottem is your coolant temp sensor.
alright, i will try and get that all sorted out today.....where does the plug for the reverse/backup usually come from??
That one is usually located on the accessory harness. its should be around the harness near the fuse box or around the coolant reservoir location.
