Can improper clutch adjustment cause slippage?
PitBull
Oct 19, 2007
Huntington Beach, California
My clutch is slipping under boost and the clutch pedal seems out of adjustment. I have little tension on the pedal until 3/4 the way depressed, at which point the clutch will disengage. Can the slipping clutch be caused by improper adjustment of the rod or am I going to have to buy a new clutch?
Yes, it can. If you adjust the master cylinder push rod all the way, it'll slip like butter on a hot skillet.
Yeah, it's slipping pretty easily. I forgot to mention that I have to pull the pedal up with my foot, if I don't it will eventually come out on its own, within a couple minutes. It seems to be sticking when I release it. The milage is 100k.
100k on the original clutch? Check your clutch master and slave, it might be leaking.
Before you start modding, do a complete tune up. When was the last time you did your maintenance? Read up on TECH GUIDE section.
http://www.dsmtuners.com/sub.php?page=tech
For 2G - http://www.dsmtuners.com/sub.php?page=2gtupgrades
sticking huh? Sound either your have bas hydraulic cylinders, clutch has gave and worst case scenario, your car has a symptom on crank walk. Check all of those and for the crank walk, turn the car a HARD left and see it it sticks.
