Can I Set the TT, take the key out, and put it back in?
Game Over
1,267
Jun 30, 2004
Aston, Pennsylvania
I have a '97 GS-T and I am using an old school HKS TT. I want to know if I can take the key out and let the TT idle the car for a number of minutes, but before the car shuts off, stick the key back in and turn the TT off, keeping the car running the whole time? Would I just turn it to the "ON" position or what? Thanks guys.
i have the blitz tt and yes, you can do that. Why havent you tried? The turbo timer should continue counting down and then just go back to normal.
ya you can do that no prob... i used to use that when i ran into a store.. with my apexi , ya could easly UP the number of min it would run so it would keep the car running while i was inside.
Thanks alot! I didn't want to try it in fear of hurting something, and thought it better to ask first. So, I'm guessing I just put the key back in, and turn it to the "ON" position. I will try whenever I get my car back.
yes, dont crank it again, but just switch to the on position (position before cranking) and youll be fine.
    • george bromwell
    • pma1123
    • Sdcryan1
