shhh i know
- 75
- 0
- Nov 21, 2011
Wilmington,
Ohio
Here is my question guys. On my 92 Tsi I have an upgraded 190 fuel pump with hard wire done, new plugs, wires, 2g mas, and Evo 560cc injectors. I installed my SAFCII and Zeitronix wideband in order to tune my car. What I am noticing is that when I am setting my SAFCII I am having to go on the positive side in order to richen up my car (so it won't be lean) to get a good AFR from my wideband. To my understanding with Evo 560cc injectors and a 2g mas I should actually have to pull fuel not add it.
I am also seeing that where I tuned it one time it will not have the same O2 reading the next time I am at the same RPMs. I realize the ECU will manipulate my settings a little but there seems to be extreme differences. I am logging through my Zeitronixs software and there is clearly major differences from one pull to an identical pull in my AFR.
So here is the question....do you think that a clogged fuel filter could cause this. The fuel filter has never been changed from the looks of it.
