can a 7 bolt head go on a 6 bolt block?
This is recommended, however not 100% necessary. I installed a stock (rebuilt) 7 bolt head on a 6 bolt block using 6 bolt ARP head studs with no clearance issues.
It should definitely be done. One of the headstuds holes in the head is used to transfer oil from the block to the head. If this hole is too tight it can cause oiling issues in the head.
