cam gear cover
stangtalontsi
Mar 3, 2004
dover, New Jersey
if you have upgraded cam gears can you have them without the cover on and still drive with it off or will anything happen?
I never had one on there until I just recently bought one. It's only there to help from getting debris in your timing belt and ####ing everything up. Having aftermarket cam gears isn't gonna change anything.
Yes you can drive without the cover regardless of what kind of cam gears you have. I would not suggest this though, as one small rock into the timing belt would not be good at all.
Jason
No problem. Its bad when you have a set of HKS 272's sitting in your room for 4 months becuase you spent the money on that and the money saved for gears gets spent on new alt,battery,water pump,timing belt,tensioners,pulleys and belts. I guess thats what happens when you buy a 97 with 1 owner at 51k..You get to replace all the parts :thumb:
thanks for putting that link on there for the clear cover ive been looking for one and only found them for evo's :thumb: and these will work for HKS cams and gears if im understanding correctly
Yes, also look in the vendor area plenty of pics and a good quality piece from Zaklee.
here is the set up on a toyota, found this online. Cant wait til mine looks this nice.
WOW! I'm 2wanting a clear cover BAD now, those things look pimp. But where do i find a timing belt that color coordinates with my engine bay? I've seen the blue ones, even that would be fine for my setup. If i get the clear cover it looks like i'll have to get colorfull gears as well :D
Well the Blue belt is from greddy and the purple is hks, other htan that ive only seen black for oem ones. by your pic whats your setup on slicks/rims i need them bad.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
