caluper freezing
hocky2k1
Jul 28, 2004
Elk Grove Village, Illinois
i have a chace to pick up a 91 tsi but it had a smashed door, and the driver side caliper is frozen. he is selling the car for 1000 bucks maybe less. but what would it take to get the caliper unfrozen just to buy a new caliper assembly.
thanks
By "caliper" I assume you mean a brake caliper? There are alot of possible reasons why it could be stuck. However, If you had to replace it, its a very easy job. Don't let that be the reason you dont get the car
thanks
Well the easiest thing to do is take the caliper off and place a new one on. The pistons in the caliper could have gotten dirt or something, or stuck after an emergency lock up. I wouldn't let the caliper part discourage you, the door being smashed is another thing. If the rest of the car is low milage, mint the price seems fine, but if not talk him down because of the damage since apparently you are going to pay for the repair.
yea by we found out today that with the door and the caliper* car needs paint and a new trans (doesn't go into first) so we decided not to buy it and im still shopping around ne one know of ne dsms for sale in illinois. let me know please thanks '
Not in the area, but check out Forced Performance they are selling their shop car for like 7K and it is pretty well built, some cosmetic dings, but nothing too bad.
well im going to look at a car with these mods on it today and hopefully will get it.....ACT 2600 Clutch
Resurfaced flywheel to correct step
EVO III 16g ported and upgraded 34mm internal wastegate
Turbo XS high performance boost control
2g exhaust manifold racing ported runners and collectors gasket matched
2g ported 02 housing evo matched
s.s turbo gaskets
Slowboy racing race front mount intercooler 2.5" Stainless Steel intercooler piping upgraded throttle body elbow
Greddy Type S blow off valve
Duel piston big brake upgrade front rotors and calipers
Auto meter ultra light air fuel gauge and boost gauge EGT gauge probe
mounted and #1 runner
New front axles right and left
New ball joints
New control arm
Egr blocked off
New oil pan and gasket
FP oil return line
SS oil feed line
New rotors, pads, and calipers all around
New turbo coolant lines
New clutch slave cylinder
New clutch master cylinder
New brass shifter inserts
New throttle body and gaskets
1/4" longer push rod for slave cylinder
B-g syncro shift fluids all around
Mobil-1 oil fresh antifreze new brake fluid, all old fluids flushes all around new clutch fluid
the guy said it has been in the garage for 2 years so hopefully it is a good deal.
  • Wanted 6 bolt NT water pipe
    • chrisman287
