For Sale Built 2g Street head, Southbend stg4, white 2GB, FP intake, various
nightmares GS-T
332
3
Aug 18, 2009
Pearl, Mississippi
Still have alot of stuff to sell. All prices are OBO, and none of them include shipping and p/p fees. I only accept paypal or cash. Shipping will be fedex or USPS. PLEASE ADVISE, if you specify USPS and you do NOT pay for insurance then I am not liable for damages. Recently had a member get a valve cover beat up pretty bad through USPS despite the heavy air packing material used. I would prefer Fedex from hence forth, but it will be slightly more expensive. I ship within 48 hours of payment. If you want more pics please text me @ (601)874-5386, I would be happy to text or email you some uncompressed pics. Now, onto the parts.
-(2) 2g throttle body elbow gaskets. OEM w/the oring. 5$ for both
-Forced Performance Aluminum 4" intake pipe. Has a 12-AN fitting installed for a catch can setup (can be plugged). Non recirculated. Includes the largest K&N Filter. 55$
-Fully Built 2g Head-0 miles, never even torqued down. Manley race series SS intake&exhaust valves +1mm, Supertech brass valve guides, Manley Performance valve spring and retainer kit, supertech valve seals, 3 angle valve job, ported/polished intake runners, freshly decked for MLS head gasket, inlcudes stock cams. Head WILL include the invoice from extreme PSI W/ all the part numbers should the buyer want more info. I can also contact the machine shop to see if he has the invoice, and ill see if I can find it. Head was built for 8500RPM by a local machine Shop called Jackson Cylinder head. Very reputable shop. 1300$
- BNIB Southbend stage 4 extreme clutch kit W/ cryo treated pressure plate. 6 puck sprung disk rated at 525+ ftlbs of torque. Includes original invoice showing cryo treatment. 400$
-Brand new topline revised 3G lifters. Been in a sealed container soaking in engine oil. 70$
-Punishment racing FMIC piping kit for a 2G. Ill verifiy all piping is included. Make me an offer if you want it, Core is shot. Ill throw in the couplers and Tbolt clamps that are on it, but I cant guarantee them. Flanged for a 1G/greddy BOV. Make an offer
-Used 2G starter. Make an offer
-STM EGR blockoff plate Brand new. 10$
- (2)Extreme psi fuel rail -8A/N adapters. Brand new. Both with screws. 30$.
-BNIB Extreme PSI turbo oil feed hose kit (90-99) (head location). 25$
- Hallman Pro MBC (Silver) 65$
-(2) new in bag mitsu cam seals PN-MD372536- 8$ each
-(4) BNIB NGK BR8ES spark plugs. 8$.
-3" gm mas. 30$ (2 avail)
-aluminum j-pipe for MHI turbos. 25$
- fidanza 9lb aluminum flywheel for a 7 bolt. Will need a new surface plate. 40$ SOLD
-Punishment racing 2g aluminum radiator w/ shroud and 2 mishimoto slim fans, very good condition, very few bent fins. 150$
- Oil filter relocation kit. Comes with AN lines, adapter, and oil filter with removable stainless steel filter media that can be cleaned and re-used for life. Has line outlets available for external oil cooler setup. 120$
- 2g aluminum TB elbow with an IAT bung and drilled/tapped for a methanol nozzle. Make an offer. SOLD
-'97 2GB eclipse GS-T body. little to no rust. Full interior. Good body, paint is fading but present. I'll either part it out or sell it as a roller. 5 Spoke avani 17" black rims. If you need any interior/exterior parts let me know and ill see if it would be worth it to just part it out. Chassis has 138XXX miles on it. White. Clean Title. I would really prefer to sell this whole, so if anyone has ANY interest at all in the whole roller please let me know and we will talk about a price.
-Sand blasted 2g valve cover with baffles removed and holes drilled for PVC catch can system. 60$
-2g engine and trans mounts. The front and rear mounts are SOLID aluminum, the sides are prothane poly (not inserts) mounts. Ready to install. 150$ for the set
-2g FWD stock trans. 130k miles when pulled. Fully functional, nothing broken. Make an offer.Shipping will not have to be freight.
-Stock 2G intake manifold. Make an offer.
-2g ecmlink mas cable/pigtail for using a gm mas, IAT, and gm omni 4 bar all plugged into the stock mas plug. 60$
-Dodge garage modded 1g BOV- Fully functional, I ran it with a solenoid via ecmlink @ 30psi. 65$
-Walboro intank 330lph fuel pump. Comes with a new sock, pigtail, etc. Direct fit. Stock pump from a Ford GT- 65$
