1G Building My 4G64 Hybrid NA Motor Soon Need Help!!
ibspoolin2
103
Jul 9, 2008
Gilbertsville, Pennsylvania
Hey guys i need some help. I'm trying to do some research before I build my motor. I'm goin N/A:shhh:
I heard if i put a 4G63 DOHC head on a 4G64 block that it will bolt right up and would give it a 11:1 compression?
Will it bolt right up?
What do I do with the timing belt, is it all the same?
And what about the water pump and alt. crank belt, is that all the same?
I need some help. Thanks
Kevin
Hey guys i need some help. Im trying to do some research before I build my motor. Im goin N/A:shhh: I heard if i put a 4G63 Head on a 4G64 block that it will bolt right up and would give it a 11:1 compresion? will it bolt right up? what do i do with the timing belt is it all the same? and what about the water pump and alt. crank belt? is that all the same? i need some help. Thanks
Kevin
i know that the 64 has a taller deck height. so you will need a longer timming belt. that is one thing iam sure of.
all i can say man is just research the forms..there packed with info..
    • george bromwell
    • pma1123
    • Sdcryan1
