Brode UICP/1g BOV install - too much boost now?
tylerk
152
Sep 28, 2003
Cambridge, Massachusetts
I installed my Brode UICP and 1g BOV yesterday, and my boost increased from about 11 psi (if I was lucky) to spikes somewhere around 20 psi and holding steady somewhere in the 15-16 range. Since it's not holding boost over the 15-16 or so, should I worry about the spikes?
Thanks for the replies. I will get a boost controller on there ASAP, and that should hold the boost steady and prevent spikes?
Is it normal to see boost spikes when upgrading the uicp? I wasn't aware that this would be a problem and am now hesistant on getting a new uicp without a boost controller first.
On the 2g's the Compressor Bypass Valve (BOV) acts like a boost limiter and leaks off the spike (this is also why by just replacing the UIC pipe is not enough and you have to get a new BOV in order to get more boost). Once you have a BOV that doesn't leak at low levels you can and will get spike and that is why you need a new boost controller (since you replaced the factory one ;) ).
