Isphius
- 0
- Sep 4, 2006
Long branch,
New Jersey
Im an experienced turbo/hotrod guy, but i got this car off my friend as he needed some money. he also knew very little about this car, just got it to mess with the boost/electronics as he is also a carb/mustang/motorcycle guy.
What i know about the car, and then what i need help with
96 talon awd, 6 bolt swap, dogbox trans (very noisy? normal?) safc2, evo 3 16g, 3 inch exhaust, tial WG. FMIC, i installed RC 550s because old injectors where unknown, and set up the safc2 the way i found on RRE.com
The car runs pretty good, doenst idle well but runs around off boost quite well. The autometer lightshow gauge wired to the factory o2 reads lean almost all the time, but the car does smell like its running rich. I cant really tell. I have an aem wideband waiting to go in tomorrow.
Boost makes it to about 10 psi, then cuts out/misses/breaks up with the safc in karman mode. If i switch it to hot wire or pressue, it runs great in boost but terrible otherwise. EGT stays around 1000, is this normal?
Tomorrow im going to do plugs and wires, boost leak test/fix, new o2 sensor, wideband install, and a new(used) MAF from a running car as mine has the honey combs punched out, and im getting an MAF check engine light code. Im using the torque app and a bluetooth obd to scan it for now
I need ideas on other stuff to check out, i know the 6 bolt swap can have its complications BUT the car does run quite well, starts right up cold and drives around normally just fine. is there really anything that could be wrong other than the CAS hack?
. I love the way it sounds though and I hate to even think about getting rid of it, but the tickets here in Virginia are ridiculous. Yours looks pretty close to stock and I think thats the look Im going for now to draw less attention.
Yeah with 550s and unknown fuel pump (and assuming pump gas) that can be risky going over 18-20ish psi, at least in my experience. If it was me, just to be safe, I'd dig that boost controller out of the trash at least until you get everything else ironed out.
