Brake Upgrades
slow99eclipse
71
Sep 30, 2003
I have aftermarket Brembo's and Russel SS lines. I want to add some bigger calipers to the front and rear. Where can I buy some and still use the parts that I already have? I emailed Baer and they said that I would have to use all their stuff, I can't interchange the parts. I know about the 3000GT swap but I want to add 4 or 6 piston calipers. What should I do?
All i know is the 3000GT VR-4 has 4-piston, which is still really good. The 6-piston is going to have to be from a company. Good luck tho :thumb:
Other than that mentioned above, the parts you may have a visual on such as; Brembo, Baer, AP, Wilwood, Alcon, Stoptech, and many more are all going to require a complete conversion to their respective kits. Between the bolt centers, radial height, and mount offset none of these companies will have 'off the shelf' parts for you.
