2G Brake caliper crush washer size
TehRiceBandit
317
53
Dec 12, 2013
Bay Area, California
Easy question. 2g front brakes banjo bolt crush washers, what size are they?
I have only one car, so no, I can't take the line to the parts store. Just spoke with the local Mitsu parts guy he didn't know either, not that I'm surprised.
MA111832
GASKET, BRAKE FLUID LINE
The crush washers for the banjo fittings would be 10mm. You will have an easier time getting 3/8 copper crush washers which work fine as well. My advice would be to just get an assortment pack so you do not have this problem later. An assortment pack would run about $10. Don't forget you will need two crush washers per banjo bolt.
