TurboMania
- 0
- Nov 7, 2005
Ft. Wayne,
Indiana
Okay, i just put on a greddy type-s BOV, it's a used one from a friend. I was trying to make my BOV hit harder, so you know i took a 8 or 10 mm socket (cant remember which one it was) and tightened the nut, the only problem is i didn't realize that it was a locking nut and that the screw was an allen wrench screw, so basically i just striped the inside of the BOV, i had some boost creep from the striped hole. Now i have already rethreaded the inside and have a replacement screw (yes it is the same size too) i put a 1/4 - 28 tap and its all well. the problem is as i get through 1st - 3rd gear everything is fine, but 4th and 5th gear the turbo's compression chamber will shutter because my BOV wont open until the turbo shutters twice, i have check for all leaks possible and have fixed them. even used teflon tape. the only one im not sure about it the one you dont use on the bottom side of the BOV, is it possible that it is leaking. can anyone help me on this, I would like a turbo with the turbine shaft in one peice still.
