Boost leak test results
kennyg
46
Mar 14, 2007
Winnipeg, MB, Canada
So I was finding that my car would kinda fall on its face at around 2500-3000 rpms, and then at around 3000 it would start to pull ok. I could really hear my turbo spooling hard compared to the acceleration that I was feeling, so I figured that I had a boost leak.
Bought that kit, hooked it up and I could only get about 7-8 psi max out of it and the hissing noise of leaking air I was hearing was coming from around the head, and found that pressure was being lost into the head. When I would unscrew the oil cap or pull the dipstick out pretty much all the airpressure would be released.
Curious what would be the main cause of a loss this way? Head gasket, valve seals? I replaced the pcv valve but that didn't seem to change anything. Any thoughts?
Thanks, Ken.
what about around your intake manifold to head flange? another reason is that could have floated a valve or may have a bent vavle or your not getting good valve to seat sealant. could be the head gasket but do a comp test and see if you can locate the leak first. if it's that big of a leak to where you notice and actually hear the hissing chances are that you would be throwing white smoke out your exhaust. when you do a comp test use some soap and water in a spray bottle and quirt it around the head to help out. play find the bubbles, then get back. you might need 2 people for this task. or if you have a compressor tank and some fittings with a regulator you can moch up a continues pressure tester and use it where your spark plugs go, (BE CAREFUL AND DONT OVERPRESSURIZE YOUR CYCINDARS)
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
