boost is VERY LAGGY!!!!!!!
DSMinduction
Nov 19, 2006
Venice, Florida
well i put my transmission back in the car, and now i barely get any boost i think i might have 5psi by 5000rpms, its horrible. i took of the o2 housing to look at the turbo blades and they are fine, no excessive shaft play, and the turbo spins very freely as always. took off the wastegate, cant find anything wrong with that. all bolts are tight on the exhaust manifold. did a boost leak test, no leaks, holds pressure fine. is there anything else that could cause boost issues like this? like if the car is running rich or something?
make sure the wastegate actuator is pulling the flapper fully shut. What are u using as far as boost control. Try this, disconnect the Wastegate actuator from the boost source, go for a 3rd gear pull (watch your boost guage) if it boost fine, then you have and issue with the actuator or your controller. But 5lbs sounds like your actuator isnt closing the wastegate. Do that and report back.
i have a 41mm tial wastegate. i took the wastegate off, took the downpipe off, inspected the turbo, inspected the wastegate, everything is in perfect working order....i was thinking about it, and i know my greddy type s is old and crappy, i wonder if its leaking, which would make sense, maybe the line could be kinked also. i might just try to find a crushed 1g and see if that helps.
If your Type S is leaking you know it after a boost test. How much PSI are you testing it to?
i didnt test that high, just enough to see if there were any couplers blown off or anything. maybe 5 psi at the most.
this is my original account btw (dsminduction)
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
