Boost Guage
eclipse420ags
259
3
Feb 20, 2010
Martinez, Georgia
Ok so I just got an autometer mechanical boost gauge and everyone says to hook up the lighting to the cig lighter, but there is like 6 different wires back there. Obviously the black one is ground but which one is the illumination wire when you turn on the lights?:hmm:
It depends on which way YOU want to do it. I personally have it hooked up to an auxiliary wire that only powers up when my lights are turned on. However, I know others who run it from the tail lights, or a source from the radio (I don't know about this one) so it's really your choice on what you'd like to do. Have you figured out that much and that's why you're trying to tap the lighter source or just went with the he did it so, I'm going to follow? Either way to answer your original question the lighter wire is black and silver blue and silver green and brown. I BELIEVE most tap into the blue and silver.
Seems to me like you're going to be the pilot of your modification crew so do yourself a favor and invest in the 12V and or a voltmeter so you can help yourself better when you start breezing through these projects.
you could also, use an open spot on your interior fuse box that has power when you turn the car to on. if you do that, go to autozone and get a fuseable link( I believe that is what its called). its a fuse with a wire coming off of it.
Mine is wired into the illumination wire going into the stereo.
That's how I did mine too. I like that they dim right along with the dash lights instead of staying on constantly. I also put in leds in the dash and gauges to help with the load on that circuit. It was easy because I had an aftermarket radio with an adapter plug and wasn't going to use the dimming feature on the radio so the wires i needed were right there.:thumb:
my illumination for my autometer gauges i have wired to the cruise control so i can turn the illumination off at night with the cruise and no extra switches. Havent seen anyone else do it this way yet have been running this way for 2 years with no issues my switched to gauges is threw radio i think same one i have my turbo timer on.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
