Boost guage Install
montes24
87
Apr 8, 2009
Augusta, Georgia
I just recieved my autometer ultralite boost guage and i am trying to install it where do i tap in the hose for the guage?
If you can please provide a pic of where to tap in the hose I also got a fuel pressure regulator can i tap into that?
There are a few options you could tap into the vacuum line coming off the P On the throttle body, the line that goes to your BOV or your FPR lines. I would use the P line off the throttle body its close and you don't have to worry about getting a vacuum leek to the FPR which would be bad under WOT.
<a href="http://s22.photobucket.com/albums/b326/dannimax/?action=view&current=solenoids.jpg" target="_blank"><img src="http://i22.photobucket.com/albums/b326/dannimax/solenoids.jpg" border="0" alt="Photobucket"></a>
The right-hand solenoid, marked with a green dot, is the fuel pressure solenoid. This solenoid allows the engine control computer to temporarily raise the fuel pressure for hot starting purposes. This is accomplished by cutting off the vacuum hose going to the fuel pressure regulator. It is not used for anything else, but it can provide a useful tap-in point for a boost gauge, since the regulator "sees" the intake manifold pressure. (If you tapped your boost gauge in here, but it doesn't read any vacuum right after warm or hot starts, you probably connected to the wrong side of the solenoid.)
This is from Virtual Tour of the DSM Engine Bay - Top index alot of questions can be answered with this site
Ok thanks guys I'm going to tap it off the FPR..and see what happens..It shouldnt matter with an after market FPR right?
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
