Boost Controller
1gengsxz3
129
Jan 25, 2007
Novato, California
ok so i want to get the dejon tool high/low boost controller and was wondering how this setup worked. and also if i did use it how would i set my boost choices and then last wouldn't i have to have my air fuel ratio changed to work with my new boost's?
are you really serious?? Before you start blasting the boost, do yourself a favor and read the tech articles on how your car works. you will answer your own questions.
Definently, take a look at the upgrade paths. Depending on how much boost you want to run your going to need supporting mods for it.
Take a look in the tech/diy section at the top of the page and go to the increase horsepower for 2g turbo. youll find the info you need in there
first i have a 1 gen i don't rock with the 7 bolt crank walk secondly if you don't have the answers don't waist the space on the thread and in the tech section the third thing on there is a boost controller thanks for nothing you two
Let's start over shall we.
1. Please use proper grammar, spelling, PUNCTUATION and capitalization in tech section.
2. 9awd4g63tsi2, got nothing good to say, move on to a different thread.
3. Without any fuel mods, you're limited to how much boost you can run, typically about 15ish psi. Only through logging will you be able to tell for sure as every car is different.
Which one are you looking at? The one that does stock and higher boost or the one that does the low and high boost but both are above stock setting?
So im going to go ahead and assume you forgot to list in your profile that you upgraded your fuel pump and maybe got some new injectors to support higher boost?
Read the whole upgrade path before you decide to throw a fit. We're not trying to shatter your dream of having a boost controler, just making sure you're set for the increase in boost. :rolleyes:
Since he atleast has a boost gauge, i don't see why he would need fuel mods to atleast turn up his boost to levels that his stock fuel set up can handle.
Stock fuel system is really only good to around 16Psi or so. If your only planning on uping the boost 3 or 4 psi... then go for it. But why not get some minor upgrades and go for some more glory?
