Idiot Stick
- 225
- 1
- Sep 23, 2002
ok here's the deal, 91 GVR4. put a different 14b on, started it up, burn off all the excess crap, didn't even smoke to much out of exhuast, let it idle for a while, filled up the collant. took it for a spin. drove fine, boosted a lil and everything seemed fine. boosted moderately, and i notice a huge cloud of smoke behind me. the car is just bellowing out white smoke constantly. park it, coolant is all gone. no visable leaks or anything, did a compression test, 150 all across. now i have yet to drain the oil, but the dipstick looked alright, and this was late at night so i didn't see if i could see any water on the piston. now i didn't loose any power or anything else like that. blown head gasket, maybe cracked head?
little background on the car, the car had sat for atleast a month, motor hadn't seen boost in a while, 154xxx miles. temperature gauge doesn't work now after the install, don't know if i broke the sensor on accident or what, i did remove it and put it back. now why would that thing be fine, then hit a little boost and just be a smoking bandit now? and the turbo is fine, so that's not the case....help? now i know coolant flows to the throttle body on the 1g's, could that be getting in there somehow? this is my first 1g so i'm a little new to it. i should be doing a leak down test as soon as i get a hold of one.
