Blown gasket. Do I need a new motor? HELP
CheaCheaBoy
139
Nov 25, 2004
Boston, Massachusetts
Ok I was driving and got off the highway.
I let my engine cool down because I was driving for about an hour.
I then revved the engine out of curiosity to heard my BOV.
Then I saw smoke coming out of my engine.
Gasket leak from my exhaust manifold?
So then one day, I stepped on the gas to feel the full potential.
Kinda stupid after I knew there was something wrong with my engine.
Then i heard like a pop and couldn't drive the same.
Everytime before I hit boost, my car would tremble.
I checked my engine the day that happened and
on the far right there was a lot of oil.
How do I fix this?
Not a good thing here. Do a compression test to see which piston the head gasket it broke at. My guess is the head gasket broke at or between the one and two piston. You probably boosted up adn it found the weakest place to blow out. Time to change it, if ya do drive it all your going to do is hurt the motor.
what type of smoke was coming out? if it was a blown HG then it should be very thick white smoke, and after a bit of idleing there should be condensation built up in the muffler due to water entering the cylinders.
How do I fix this?
gasket leak from the exhaust manifold is a simple and easy fix...just get a new exhaust manifold gasket...now the oil problem that you are talking about is such a broad problem it can be anything...you say there is alot of oil but where exactly is it from...
if it was a blown headgasket it would have been oil and water mixing by now...and he would be over heating by now...he is too broad with his question...not being specific enough...LOL...
it was thick white smoke.
When this happened I was able to drive back home which was a mile away.
I had to go back to college the next day, but didn't want risking taking the car.
You think I can be able to drive it to the shop (3-4 miles).
I think its possible to drive if under 3k rpm, but should I?
  • Wanted 6 bolt NT water pipe
    • chrisman287
