gusu
- 1,950
- 35
- Sep 9, 2009
Independence,
Oregon
First off this is for a 1990 Talon. The 1991, 1992, 1993, and 1994 have a "jumper" not a relay.
A few years back I had a issue and pulled the jumpers out of a 91 and a 93 Talon. I don't know where I put them after moving so I was hoping to replace the relay or find out what the name of the jumper is to buy one.
The relay is a 56700-5260 and besides Ebay having a couple questionable ones I can't seem to find them anywhere.
I'm sure the jumper would probably be easier to find if anyone knows what it is called. It's the wire set that would normally be connected to the blower motor directly. As a relay it is a 4 pin. As a jumper it is a 2 pin where you could easily tell it used to be a 4 pin.
Anyway, thanks for the advice.
