2G Block surface
Kpro22
73
Jul 15, 2016
San Diego, California
During the process of removing the dowel pin , I Slightly nick the surface of the block . Will I be ok using a composite gasket?
I'm not an expert but it doesn't look like it's bad enough to cause any issues. It doesn't go to the edge of the block. If you feel comfortable you could probably file down any edges that could be sticking up if it has any.
It's fine, not even close to anything that holds pressure, and it's too small to be concerned. If you're completely rebuilding the engine, a deck surfacing to clean up is usually in the cards anyway.
