Blew my trans yesterday
WOTDSM
167
Dec 3, 2006
Detroit, Michigan
So I was driving around yesterday and I saw my friend with a stage 2 WRX pull up next to me. He down shifted and wanted to race so I threw it in 1st at about 10 mph and we started going, I was hanging neck and neck with him (DSM power FTW) redlined 1st, redlined 2nd, not knowing my own strength I kind of slammed 3rd pretty hard and the shifter went to 3rd but the gear wasn't engaged so I went to 4th. 4th worked and I went for 5th but it was locked out... I kept it in 4th, pulled over, put it in neutral and let the clutch out but it was still as if a gear was engaged. I figured I just slipped a cable so I pulled over, low and behold a cotter pin on the shift lever broke off and my cable was almost off the lever. I fixed that and fired it back up. The damage had already been done... no matter what gear I put it in its as if its stuck in 4th unless I try reverse then it's just like a park gear it just kills the motor. I'm thinking I actually did slip a cable and had I not gone to 4th everything would have been fine? But shifting into 4th broke or bent a shifter cable.
The trans had 155,xxx miles and bad 1, 2, 3, and 4 synchros so I don't feel too bad but it sucks :(
Sounds like you may have broken a shift rail. I broke mine when I shifted hard into 3rd, and the car was halfway locked into 2 gears.
