blew my koni yellow shock
Black95TSIawd
2,620
411
Jan 28, 2003
Dirty, New Jersey
So my koni yellows have about 4k on em. I originally had them on some B&G lowering springs. It was probably 1.5 inches lower all around. I recently put on my hyperco coilovers with hypercoil springs and within a week, I blew the rear right shock. I'm stunned. I do not have the car dropped excessively. There is roughly a 2 and a half finger gap in the back and i run 225/45/17 tires. Does anyone know of or recommend a shop that rebuilds koni's?
Perhaps its a defective shock. It may be under warranty.
Also, how are you sure only the RR shock is blown?
I had the car on a lift yesterday and there is green fluid all over the shock. Also, I can definately feel the the difference in sag and handling when taking a left turn as apposed to taking a right turn.
Like project tsi said. I would check the warranty on the struts. Did you order them on-line or at an actual shop near you? But I would FOR SURE check the warranty on them first. You say they have 4K on them, but how long day/month wise have you had them? That may affect the warranty. And Im sure if check Koni's website out, they have some info for you.
Here is the link to their warranty information. I hope this helps.
http://www.koni-na.com/warranty.cfm
