KFred 513
- 146
- 0
- Oct 11, 2012
SUllivan,
New York
So I know this problem has been covered many times, but solutions are rarely posted. The few people that follow up with a solution fixed their problem with something that has checked out in my car.
I have had the car for less than a week and on day 3 it started to studder/hiccup unpredictably. DSM link never logged a misfire. The miss was independent of any factor I could control (RPM, throttle%, AFR, etc.) The tach would also skip around with the studder. We swapped in a working power transistor with no effect. The problem only occurred after the motor was fully warm. The miss went on for a few days and then disappeared for 2 days.
Yesterday while cruising in 5th gear the car stuttered worse than ever and never recovered. After a quick examination I had to continue to drive the car home about 10 miles. At a friends garage We quickly realized the car was only running on cylinders 1&4.
I thought the motor was toast so we started a compression test. The compression checked out at ~150 across the four. Then we tested spark. All four plugs have spark. A noid light showed that all 4 injectors get signal. We checked the timing, and of course, the crank jumped a few teeth. We corrected the timing, but no change. I pulled the valve cover to make sure the rocker arms were all in place, they were.
Tonight we swapped in a working CAS, with no change. We also tried spinning the CAS rotor by hand with it plugged into the harness.One thing we did notice was That on my buddy's car, every 1/4 turn caused an injector to fire. On my car every 1/2 turn caused an injector to fire. This was using the same CAS.
I am really at a loss here. The problem only happened yesterday but we have spent a good amount of time on diagnosis with no change. We know that 2&3 aren't firing because both injectors can be unplugged with no change.
Sorry for the long post, but here is the mod list so everything is out in the open. I'm just pasting it from the craigslist ad.
Engine:
90' 6 bolt stock block w/ Wiseco rings and ACL tri-metal rod bearings
97' head (6 bolt converted)
94' black top CAS
BC 272/272 cams
Fidanza Cam Gears
ARP Head studs
ARP Exhaust manifold studs
Balance shaft delete
A/C delete
Quad layer metal HG
Fluidampr harmoic balancer
Ignition:
Coil on plug (Intrepid coils)
MSD DIS-2 high output ignition amplifier
NGK BPR7ES plugs
Intake:
Q45 90mm Throttle body
JMF street intake manifold
Magnus heat barrier gasket
FP 4in intake
ETS 10.5 street intercooler and piping (anodized black core, black piping/ couplers)
Tial 50mm BOV
PTE HP5857 billet ball bearing turbo (oiled from head with in-line earls filter)
K&N filter
Exhaust:
RRE 3" Downpipe (V-band)
Full custom SS 3in ID piping
FP race manifold
Punishment racing 02 housing (recirculated)
Tial MV-S Wastegate (water cooled)
Megan Racing Muffler
Suspension/ Handling:
Ingalls rear camber kit
Tokico Illumina struts
Tokico 1.7 inch lowering springs
Energy suspension bushings
-front upper control arms
-front lower control arms
-rear trailing arms
-rear upper control arms
-rear Knuckles
Prothane motor mounts
Megan racing front strut tower bar
RRE rear strut tower bar
Brakes:
SS brake lines
Brembo Calipers (Evolution 9 powder coated black with white lettering)
Evolution 9 rotors
KMV adapter plates
Drivetrain:
Fidanza 8lb flywheel
Fidanza 6 puck V.2 clutch and pressure plate
Extended slave cylinder rod
Energy Suspension shifter bracket bushings
Full length SS clutch line
Skateboard bearing shifter bushings
95' LSD rear differential
Fuel:
Walbro 255lph HP fuel pump (rewired)
F.I.C. 1000cc Injectors
Fuellab mini FPR (w/ gauge)
Fuelab in-line filter
-06an ss/cloth braided#line from tank to FPR
F.I.C. fuel rail
Management:
DSMLink V3 (Speed Density, NLTS)
AEM Wideband gauge
AEM Tru Boost gauge and controller
AEM Oil pressure gauge
AEM Water Temp gauge
AEM Volts gauge
AEM 3.5 bar MAP sensor
GM IAT sensor
Greddy turbo timer
ECMtuning V3 GM MAF harness
Cooling:
Koyo aluminum radiator
Maradyne 12" fan (pusher)
Mishimoto 12" fan (pusher)
JM Fabrications overflow tank
Miscellaneous:
CF Hood
Evo 9 Enkei rims
Battery relocation (trunk)
Shaved valve cover (6 AN fittings)
JM Fabrications Deluxe catch can
Jay Racing Alternator relocation
Vibrant vacuum block
NRG steering wheel quick release
NRG steering wheel hub
No name steering wheel
Imperial power steering cooler
Non-cruise control cable
Engine:
94' black top CAS
BC 272/272 cams
Fidanza Cam Gears
ARP Head studs
A/C delete
Quad layer metal HG
Ignition:
NGK BPR7ES plugs
Intake:
FP 4in intake
Tial 50mm BOV
K&N filter
Exhaust:
FP race manifold
-rear trailing arms
-rear Knuckles
Brakes:
SS brake lines
Evolution 9 rotors
KMV adapter plates
Drivetrain:
Fuel:
F.I.C. fuel rail
Management:
AEM Wideband gauge
AEM Volts gauge
GM IAT sensor
Greddy turbo timer
Cooling:
Miscellaneous:
CF Hood
Evo 9 Enkei rims
