Big Tranny Problem
dalecitytsi
Oct 15, 2003
Dale City, Virginia
I have a BIG tranny problem. I have a 91 fwd talon. Its been modded it all that. Everytime I get into it the bolts in the tranny break. I put grade 10 broze coated bolts in it and the tranny still broke a way from the engine. Could someone tell me how to fix it?
First off I have no idea what the hell you just said. Now, if your tranny keeps seperating from the block you need to check all the mounts. There are 4 main mounts. One in front on the crossmember, one in back on the motor, one on the left on the motor and one on the right on the tranny. Make sure they are all in good shape and not torn and replace as necessary. If they are in good shape then you shouldn't be able to move the tranny enough to break those bolts.
