dsmotors09
- 32
- 0
- Sep 13, 2007
Topeka,
Kansas
What are the best parts for an automatic DSM to run 12's/13's (Cheap)
Remember you will need to do some port work on the intake many if your gona go whit a 1g throttle body ..
You will also need an AFPR whit a 255
Not true, I ran a 255 high pressure walbro with 1000cc injectors and a stock feul system other than that. But yes, a fuel pressure regulator would not be a bad idea at all.
in no particular order:
SSAC FMIC + 1g BOV
big injectors, 225 + FPR
DSMLink
16g
TURBOback exhaust
MBC + Boost Gauge
shift and end clutch kit
O CHEAP! silly me.
Free Mods
NO exhaust.
Specture Air Filter and MAF Adapter $40.
DIY MBC $10 i hear, $50 boost gauge.
"Flip" your BOV.
550 injectors, 190 FP
Port Port Port
Race Gas
And of course remove all unecassary wieght
shift + end clutch kit
that should be a good start. then it gets expensive with Turbo/Intercooler Upgrade. but i guess you could go 14b and SSAC.
What do you think that will run?
time or cost?
time:
close to your goals... with the fuel upgrades and the 16g with DSM link, you would be limited to the size of the injectors and tune. but you can buy 1000's and be limited by stuff breaking.
cost: well it all depends on where you buy everything from. shop around, ebay, classifieds.
my guess would be
$500ish for Fuel mods
$500ish for Dsmlink
$400ish Ebay DP, 02, Catback
$350ish for IC + 1g BOV set up
Turbos you can try n hit your goal with a 14b that you could find for like $120 if you wanna keep the budget low. but a 16g will cost u +$500. unless you go Ebay- but thats a forum in itself.
$60 Boost Gauge
$50ish for a MBC unless you try n make your own for $10
tranny upgrades will depend on if you do it yourself... so add the parts plus the mechanic costs.
There's only one way to find out! don't forget a tuning device for everything! I ran a 13.8 with a s-16g and supporting mods, with no internal work or tranny upgrades.
What mods do you have to run 10 sec?
