Best quick release hub
I have the Sparco quick release and love it. I would say Sparco is one of the best. SPA makes a good one too. You have to base it off the ease of removal. The cheap ones you have to press a button down so u can pull the sleeve over it, horrible design, but cheap to produce. The Sparco and the SPA works by male and female splines that fit together, to release you just pull back on the collar and it releases . They are expensive, but you did say you wanted the best. The best will cost you. :)
Thanks for the advice. Ive been shopping around and it sounds like the sparco is pretty well built. I already have a set of sparco fighter seats in my car, so it would make sense to have a sparco quick release and steering wheel.
Also does sparco only make one quick release hub?
