2G best 2g awd suspension setup?
philpuc269
Sep 15, 2007
lexington, Kentucky
I have just recently gotten an 99 awd. i am looking to take this car out as an auto cross but the brands that i have used in the past are not in the market of this car. I had been trying to research suspention options with many differnt conflicting results. i wanted to find good coilover set up that want brake the bank. plus i am having a hard time findind a rear upper contol arm with camber adjustment built in. I found most every thing i need to up grade the front but the rear setup has been a pain. the motor upgrades are abondant but if you can not put the power to the road there is no point. It would be great if someone could help me find a reliable source to get all of my suspention needs not just spring and struts.
First, you need to decide what class you are aiming for in AutoX. And if you are talking SCCA, you really need to pay attention the classes.
Ground Controls with Konis will be dominate.
As for camber adjustments, the rears can be done with washers and the fronts may not need any adjustment at all. I would search "DIY camber".
  • Wanted 6 bolt NT water pipe
    • chrisman287
