Bent fram?
ZooMAiRDmX
May 20, 2003
I think I may have a bent frame... Is there anything I can do myself to check to see if my frame is bent? The reason I think my frame is bent is because my hood doesn't sit straight on the car. I've called around to body shops and they've said itll cost around $40 to get an estimate. Any suggestions on what I can do (if anything) myself?
It should show in the tires, first. Have someone else drive it down the road and see if it's tracking straight. Does it pull to one side?
Find the repair manual for the body -ask the dealer to let you look- and check the engine compartment datum points.
There's a reson they'll charge you $40 to check it. And, it's a bargain.
yeah actually, the front driver's side tire is REALLY worn on the inside part of the tire. and I've noticed that the car is starting to pull to the right, slightly. Any other ideas/suggestions?
