Belts shreading after Unorthodox UDP install
billy b
Sep 27, 2004
columbus, Ohio
Yeah so, about 3 weeks ago we changed my timing belt and installed a Unorthodox UDP. Well I noticed like the next day there were a little bit of belt shavings in the engine conparment but I didn't think much of it. Well it shredded both Power Steering and Alternator belt. I have gone ahead and purchased a heavier grade of belt this time but, I was just wondering if anyone has seen this before? Everything is lined up and can't see anything wrong with it, it even flipped the alternator belt before it snapped. :dsm: Thanks guys
Bill
Make sure your pulley is on right. If it is tilted even just a little, the belts will walk and get chewed. Sounds like the pulley is not still flat. But I could be wrong.
^^^check to see if it is inline. Also check all of the tesioners, because they are the easiest to get and out line, and the easiest to fix.
Thanks guys, I checked the tensioner (sp) it is right on. Is there someway I can better test to see if the pulley is on there flat? By looking at it, it looks flat but, I can't be for sure I guess. Well, it's been like 3 days now since installing the new belts, so far so good. I am just going to keep my eye on it. I got heavier belts this time so, atleast if nothing else it will last a little longer...
