bcs lines
marin_2k2
30
Feb 3, 2004
Northeast, Nevada
I'm swapping my t-25 for a 14b. I have the t-25 out and I noticed that the lines from the bcs run to the wastegate and a fitting on the turbo. The 14b doesn't have that fitting, so where am I going to put that line?
Well the thing is, I want to have it running by tonight. I just read that there is a nipple on the j-pipe that the line should hook up to but the j-pipe that i have doesn't have a nipple on it. Should I just take the nipple off of the t-25 and tap it into my j-pipe?
yes, you can do that, if you want to make a hole in your LICP.
Or... you can run without a bcs... you will just be running a couple psi lower than stock. maybe 9 psi or so. Just plug the little hole in the intake. And, dont hook up any of the vac lines. Leave the BSC electrically plugged in. But, not hooked up to anything. Then, connect the wastegate to the BOV line with a "T".
