battery loosing charge
Codyvieth
65
3
Aug 9, 2014
madison, Wisconsin
i drive my car and the dash lights get dim and my stereo turns off and for some reason the turning signals don't work. then if i turn off the car it doesn't have enough charge to start back up. I have a brand new alternator so its pretty strange. also this happened to me just now and for some reason it started back up after i let it sit for a bit but then it slowly started dying again like before.
I would take the alternator back and try another one you could have got a bad alternator. Or check for loose wires
i had a ECU that caused battery drain. the car still ran o.k. but it would occasionally do odd things. the ECU still looks good on visual inspection also. i would think new caps and cleaning the terminals and inspecting some of the solder joints would fix it but i had a spare so i swapped it for now.
it had that exact issue of being fine for a few days to a week, then one morning the batter would be dead. i could drive the car a lot or a little, alternator checked good, replaced alternator, startor, starter relay, did fuel pump rewire, fixed car of any and all codes. issue still happened. swapped to a known good ECU, random battery drain resolved.
Thanks for the update on the fix, not enough people post their fix after asking a question that could be several things. And I worked at auto zone for over a year and I've seen a lot of alternators and starters come back defective. I always advise buying oem or known quality. And do you have the heat shield for the alt and exhaust manifold? It helps with longevity as heat and contaminants (oil, p/s fluid, antifreeze) will kill the alt.
  • Wanted 6 bolt NT water pipe
    • chrisman287
