Bass Help
The Sound stream 10s only require .5 cubic feet of space. What are the requirements of the 15s that you mentioned? I thought two 10 would seize most of the tire well. DO you think i can get two 12s down there?
Here's the specs on the Kicker Solo-Baric L7 15"
titanium deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 2-ohm voice coils for wiring flexibility with a compatible amp
frequency response 18-100 Hz
power range 75-1,000 watts RMS (500 watts per coil)
peak power handling 2,000 watts
sensitivity 88.5 dB SPL
top-mount depth 8-3/16"
sealed box volume 1.5-6.0 cubic feet
ported box volume 3.0-6.0 cubic feet
These retail around $450 (Crutchfield.com) but you can pick them up on e-bay for under $200. One of the best subs on the market. Also, the Alpine Type-R sounds great but they need quite a bit of room to sound good (SUV type room, but I'm sure something could be worked out).
Originally posted by sophat34
the recomended sealed volume for the diamond 12" sub is .5 cuft Ill see if I can find the rest of the specs
that is really all the specs i needed. Do they have a site i can read up on their stuff at? The other woofers were to big sealed. I know thw sound stream 12s require 1.3cubic feet sealed.
you would have to look for a set of used ones, the new ones have the same specs, but building a sealed box at .5 cuft for a 8" deep sub is pretty tough to do. the new sub specs need a .55 sealed enclosure but the sub displacement is .16 so u need to build a .71 cuft sealed encouser for each one. and they will handle a shit load of power. are you looking for single or dual voice coils? heres the web sight for the new ones
http://www.diamondaudio.com/MobileAudio/index.cfm?Page=MobileAudioHome
