bad tps?
97spyder maayng
71
Sep 11, 2004
toronto,
So i'm getting some idling problems, so i decided to check the ohms level on my TPS.
I followed www.plymouthlaser.com and instead of reading 5 ohms, im reading 0 no matter which direction i turn the tps.
I'm guessing the TPS is worn out, is there another possible explanation for this?
well if it was showing 0 all the time then the car wouldn't rev up at all ? are you sure you had the leads touching wires ? are you sure your OHM meter is working properly ?
