Sublime_06
- 81
- 0
- Oct 3, 2006
Winnipeg,
I am having a very hard time shifting through all gears. The shift cables seems like its binding or worn or something..
I disconnected the shift cable at the transmission and went through the gears manually and everything was buttery smooth. After hooking the cable back up and trying it is really hard to go through the gears.
I figure it has something to do with the shift cable, but I am not sure how to tell if it is bad or if there is something else that might be causing the problem.
Any help is greatly appreciated. It is a 1995 GST.
Thanks,
Chris.
Thanks,
Chris.
