Bad oil leak...
TSi92
471
Oct 18, 2002
Wahiawa, Hawaii
Ok I have this very bad oil leak... the thing is that I can't find it! It seems to come from the front engine cover area. The leak seems to happen only when the engine has a load. There's oil everywhere on the left side of my engine compartment, even my left side wheels get covered with oil, seems like oil SPRAYS all over the place. I changed the front cover gasket resently and the front main seal, also i have eliminated balance shafts.
This is what i did in hopes to find the leak: I removed all the accesories and lower timing belt cover. Cleaned the area, fired up the engine and had a friend to free-rev it to 5 grand with a cold engine in hopes to bring the oil pressure high enough. As he was revving I had my flashlight looking at everywhere but I just couldn't see any signs of BAD leak! A small drip by the oil pan was all i saw. I stopped the engine when it reached normal temperature (no waterpump) and I just scrathed my head. :confused: I re-torqued the cover bolts and put everything back together, after a 20 mile trip or so, there was oil all over the place again. :mad:
What you guys think it would be coming from? I wish I had free access to a dyno so i could check my car with a load. Oh well, I guess I'm gonna replace the front cover gasket again. :thumbdown
hmmmm gonna bypass that crap tomorrow... but when the pvc gets plugged, it usually leaks from the valve cover right? :confused:
Originally posted by fivestardsm
Hey, you might want to check to see if your dip-stick is blowing out. It happens quite regularly. If it is, just take a pair of pliers and crimp the tube so the dip-stick fits tight.
Steve. :thumb:
And that's one of the oldest DSM quickie-fix things hehehe
YOu might have the same problem i have, I am losing oil out of the timing belt tensioner bolts
Now this is interesting... I don't remember if those bolts go through oil passages. Maybe some teflon tape would do the trick?
I have a very similar if not the same exact leak. I have yet to find where exactly it is leaking from. Replaces all the gaskets/seals in/around the front cover. I can acutally see tiny drops coming from behind the fron cover and dripping on the driver's side axle, that is why MY oil goes everywhere. I also have no balance shafts, but it only started leaking recently. I guess I am going to put teflon tape on every damn bolt in the area and see if it works.
Did you do a balance shaft removal? Because the front balance belt tensioner bolt will leak if its not there.
Steve :)
I've been on the DSM community since '97, please don't insult me like that!! :D
No harm intended! I was just giving some advice from experience, But then again I have had a lot of oil leaks that generalize from the same area, I was just trying to point out the most odvious but usually over-looked. I have also had the filter housings crack and the oil pump's crack, and the pressure sending units develop a leak around thier bells . But those are less of an occurance. Just trying to help.
Steve. :|
