Bad 02 sensor? a few questions.
talon187
1,043
Feb 11, 2003
torrington, Connecticut
ok i have a few question maybe someone can answer for me. if a 02 sensor goes bad will it cause a cel light to go off? the reason im asking is because right now i am running a maft and safc2 and when i go over about 5k it almost bogs or hits a limiter someone told me a bad 02 sensor could do this i was wondering if this were true
If your o2 sensor craps out completely then the ecu will throw a code. As for the car bogging it almost sounds like your getting fuel cut? are you modded? Also do you have a logger?
A bad O2 can set a code, but it sounds like you may have other issues. The ECU completely ignores the O2 sensor when in open loop (during WOT and warmup, for instance) and the car runs just fine.
no logger as for mods
aem wideband
safc2
maft blow threw setup
bushur race core short route piping
2g ported manifold
tial 38mm wastegate
huge 02 hosuing
3inch apexi turbo back exhaust
16g turbo
mbc
255 walbro pump
550 injectors
fpr set at 38psi
steel braided fuel lines from the tank to the rail
boost gauge
water temp gauge
fp intake tube
9:1 weciso .20 over
eagle rods
stock rebuilt head
4 layer mitsu head gasket
arp head studs
arp mains
arp rod bolts
no balance shafts
when the car gets at wot at 5k goes to 9s for a/f ratio could a boost leak cause that? the last time i checked i had no leaks and it was still doing this i cant figure out why its going so pig rich all the sudden any input would be great.
i checked my 02 sensor once it the tip inside the 02 hosuing was white should it be this color?
    • Sdcryan1
