Automatic shift knob removal
There is a screw behind the lever, put it in 1 gear then use use a small screw driver to undo it then pull it off, ive only had to move mine up a little bit so ive never pulled it right off. Becarefull if a spring or clips to hold the shift lock button dont fly out
