audi a6 hid conversion guide?
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
I believe I read somewhere about the process to retrofit audi a6 projectors into projector headlights for the 2g eclipse. For some reason the search function isn't returning any results at all for me so could someone please post the link? Thanks
I put A6 HID into my car. All I did was bend the metal strap that holds the headlight bulb so it would hold the HID bulb in. I found a spot for the ballast and secured it. I made up a relay wiring harness that pulls power from the battery to feed the ballast and only used the stock wiring to provide signal for the relay to open.
Theres not really much to it.
