ATI damper clearance issue
ali_viento
117
3
Feb 26, 2007
Dubai, Asia
Hi Everybody,
I just want to recheck the timing belt/ auto tensioner and since i already installed the ATI damper when i wanted to remove the outer damper to remove the timing cover then there is a clearance issue between the outer damper and body and it seems its not possible to remove the damper normally and must lower the engine , is there any body have the same issue ?!
Thanks
