arp studs causing clearance issue
Clipse90Turbo
136
Sep 15, 2003
Indianapolis, Indiana
I'm building up a 2.3/2.4l stroker engine and after the install of the crank and bearings there was a problem when the arp studs where put on. You couldn't turn the crank really. Has anyone had this problem? I was confused of why these studs would cause this. Now my block is at the machine shop getting aligned. If anyone could help me out that would be appreciated...
Thanks
:tease: :beatentodeath:
Did the crank turn with the stock main bolts? Some people say you need to line hone the mains when using arp studs. Personally I can't see them tighten the mains enough to clamp the crank down, but I guess it's possible. From what I've seen, line hone jobs don't really make the mains straight or round anyway. Let us know what the machine shop says.
