ATF temp
96boosted
Apr 5, 2003
I am about to install an ATF temp gauge. I was wondering what is the max temp I should see and what is safe. I remember seeing a thread about this, but I can't find it anymore. Spent the last hour searching... I give up. Can someone give me a hint?
-96boosted
-96boosted
Ideal transmission temp is 150-190, anything above 210-220 is probably cause for concern.
-John
Thanks again John! What will we do without you. :) Maybe this can be added to the "Extending Automatic Transmission Life" thread. It would probably help out a lot of people.
-96boosted
A few more questions, where should the temperature probe be? I was thinking I can T into the return line. Would that give me accurate enough reading? Also, what is the best set up:
A: tranny -> stock cooler -> B&M cooler -> tranny
B: tranny -> B&M cooler -> stock cooler -> tranny
Does it matter if I mount the B&M cooler in front or behind the stock cooler? Or that depends on if I pick A or B?
thanks,
-96boosted
  • Wanted 6 bolt NT water pipe
    • chrisman287
